My heater is not working, I smell no anti-freeze and the engine is not running hot, My question is should I be looking at the heater coil or a noew thermostat.
Thank You
Thursday, April 29th, 2010 AT 7:48 AM
MECHANIC
Check the heater core if its clogged-up and heater control valve, since its not running hot -thermostat is okay
SPONSORED LINKS
Tuesday, December 20th, 2016 AT 6:16 PM
GREENT
MEMBER
I've been messing around with it and I now get warm air not hot and the hose going into the coil is hot do you thing I can fluse and fix the problem or should I fuse the hold system and replace antifreeze
