2003 Ford Windstar leak
120,000 MILES • 6 CYL • FWD • AUTOMATIC
JLIMONTA
coolant leaks out all the way over short period of time. we have had it checked and they found no hoses broken or leaks? I can see it leaking under can in center. the antifreeze smells up the car inside and out. the thermostat does not go up or seam to over heat.
May 28, 2010 at 4:37 AM
JIS001
  • 3,412 POSTS
If you actually see a drip on the floor, then pressure testing the cooling system should expose where the leak is.
May 28, 2010 at 4:43 PM
