2003 Ford Windstar Heater not working
MRTANGOGUY
  • 11 POSTS
Heater problem
2003 Ford Windstar V6 Front Wheel Drive Automatic 78908 miles
heater doesn't work. Banging sound coming from under dash . The pitch of the sound changes as I move the heat control from hot to cold. But still no heat at all . I bealaeve it is a problem with the control module but not sure what to do to check. I would be grateful for all help . Thank You .
Dec 2, 2007 at 3:10 PM
MACMANJIM
I have the same problem with a 2003 Windstar It makes a clicking sound when the heat is on and blows cold air in the front. It sounds like it is coming from the plenum under the dash. If I select a certain heat range for the front slider, it will stop. Any clues?
[quote:2f0f50f1cd="mrtangoguy"]Heater problem
heater doesn't work. Banging sound coming from under dash . The pitch of the sound changes as I move the heat control from hot to cold. But still no heat at all . I bealaeve it is a problem with the control module but not sure what to do to check. I would be grateful for all help . Thank You .[/quote:2f0f50f1cd]
Dec 20, 2016 at 10:10 AM
04BOLT
  • 7 POSTS
blend door actuator
