2003 Ford Windstar Engine Stutter
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
JARROD1
upon acceloration if you go over 2,000 RPMs the engine
stutters and van stops pulling every now and then the engine stalls.
you can shift into neutrul and engine still stutters.
you can put it into park and engine will rev up but at 2000 RPMs it stutters some and catches back up at 3,000 right before it hits the rev limiter.
when on the road if you turn it engine off and restart van will run fine for a few miles then it same thing again.
Dec 20, 2008 at 6:17 AM
SCHRIMPIEMAN
  • 166 POSTS
Do you have a "Check Engine" light? Extracting the code with a scanner would help a lot in diagnostics.
First thing I'd do is get a sample of fuel by disconnecting the fuel filter at the "in" side and running the fuel pump for a few seconds into a clear container and making sure no contaminants come out. At the same time while you're pouring fuel into the container, hold your thumb over the opening (without getting fuel sprayed into your face/eyes just to get a feel for the pressure. While this is not an accurate measure of fuel pressure, you can at least get an idea. If the fuel sprays out past your finger in a fine mist, your pump is good. If you can easily stop fuel flow, you likely have low fuel pressure; get a fuel pressure gauge to verify. While the fuel filter is off, replace it w/ a new one. Reconnect and test vehicle.
You might need a tune up based on the mileage, especially if it hasn't been done before. Spark Plugs and wires are most affected. There aren't many more expendable parts in the '03 Windstar other than as mentioned and the air filter.
I own a '98 Windstar and had a similar situation, engine would bog and sputter similar to your description. However, the problem in my case was a speed sensor which was not engaging with the transaxle turbine output shaft gear. Check and see if while you are driving that your MPH gauge is steady or fluctuating wildly. In addition, activate your Cruise Control on a level surface void of other traffic. Lightly put your foot on the accellerator pedal just to feel it move (no pressure on pedal). If the "gas" pedal is vibrating or hunting for position, this is a good indication that the VSS (spd sensor) is not receiving a good signal and needs to be diagnosed. Unfortunately in my case, it wasn't the speed sensor which wore out. The turbine shaft gear was the culprit and the entire transaxle needed to be removed in order to repair. Needless to say, the transaxle was rebuilt while it was outside the vehicle.
You may ask "what is the relevance of a VSS to having the engine sputter?" Well, the transmission control module communicates via network with the (PCM) powertrain control module (tranny talks to engine computer) and tells the PCM how fast the vehicle is travelling. Based on this information, the PCM does engine load calculations, compares it to other input sensors, and then determines stuff like ignition timing and fuel injector pulse width. If the VSS is out of range, the PCM cannot accurately keep the engine running, and things get whacky.
I hope in your cased, it's just a fuel filter or contaminated fuel.
Dec 21, 2008 at 9:38 AM
JARROD1
i hooked up scan tool and it was showing lean error code....
so i check fuel filter and it was plugged up...
bad fuel and water too
its all good now...
you hit it right on the head
Dec 21, 2008 at 12:33 PM
SCHRIMPIEMAN
  • 166 POSTS
I realize my input was after you already made repairs, but thanks for letting me know I was correct in diagnostics.
Hopefully others with similar situations can benefit as well.
Dec 21, 2008 at 12:55 PM
JARROD1
Thanks for your help ! Next time I may not be so lucky and won't figure it out !!
Dec 21, 2008 at 11:01 PM
