2003 Ford Windstar Drivers window stuck
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBORICH008
Wife put window down to talk to friend. Window will not roll back up. When you press the driver's window button in the up direction, There is a single click under the dash, but no motion or noise from the window. All fuses have been checked (under hood and dash), all other windows and controls work. Does anyone have any idea what might be causing this? This happened once before, about a month ago. The window started working the next day then. It's been down now for 4 days, and heavy rains are in the forecast. Please help
Sep 25, 2010 at 8:00 PM
BRICKY70
I had the same problem on my 99 windstar. All i did was take off inside door panel and find window motor, then press the button while gently tapping the motor, and the window started to work again.
But be cearful because there is not alot of room, as soon as the window moves stop pressing the button, remove your hand then press up and down a few times. It's been 2 months since i had this problem and it still works.
Hope this will help you.
Oct 3, 2010 at 12:54 AM
FIXITMR
  • 9,989 POSTS
i just bought a high mileage 03 windstar and the drivers window did not work. i took motor out tested and it just SPARKED HEAVY but no action. disassembled it and checked and reassembled and it worked! put it back in and it worked but later in day wife put window down and it would not go back up!! removed it again and noticed when i loosened last screw a pop noise as it came free as if it was under TENSION! then i recalled same noise when i removed first time! so second time removing after pop noise i tried window again and it WORKED!! i dont know if this means an internal gear issue or a regulator or auto down setting issue! i dont like the auto down feature not being able to turn it off!
Jun 4, 2019 at 10:10 PM
