2003 Ford Windstar connection lines
55,000 MILES • 6 CYL • FWD • AUTOMATIC
JOE REECE
I tried to repair a leak on a transmission line that goes into the radiator and stopped the trans leak but now it is leaking water around the seal. Can I use a sealer around the seal. I tried the white tap but it still leaks. Help, Joe Thanks
Aug 9, 2009 at 1:42 AM
SCHRIMPIEMAN
  • 166 POSTS
I've never had any success with trying to fix plastic-tank radiator cracks / leaks. The glycol from the antifreeze is nearly impossible to clean out; thus the reason glues and sealers won't hold.
You may have to resort to a new radiator.
Aug 21, 2009 at 11:46 AM
