2003 Ford Windstar back heater core
MIKEB28
Heater problem
2003 Ford Windstar
how do you change the back heater core
Jan 21, 2010 at 6:44 AM
  • 75,988 POSTS
REMOVAL: 1.Drain the cooling system. 2.Remove the trim panels.
https://images.2carpros.com/forum/automotive_pictures/12900_hc1_1.gif
3.Disconnect the rear heater hoses.
https://images.2carpros.com/forum/automotive_pictures/12900_hc2_1.gif
4.Remove the rear blend door motor. * Disconnect the connector. * Remove the screws.
https://images.2carpros.com/forum/automotive_pictures/12900_hc3_2.gif
5.Remove the rear heater core cover. *Remove the bolts.
https://images.2carpros.com/forum/automotive_pictures/12900_hc4_2.gif
6.Remove the core from the housing. CAUTION: Do not spill any of the remaining coolant inside the vehicle. INSTALLATION: 1.To install, reverse the removal procedure. *Lubricate the coolant hoses with MERPOL(R) meeting Ford specification ESE-M99B144-B or plain water only, if needed.
Jan 21, 2010 at 8:02 AM
