2002 Ford Windstar Vehicle engine will not run, cranks well
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
SGAST
This was an interminent problem and now a permanent. The vehicle turns over (cranks) well, 3/4 tank fresh gas. It wont start.
When it was interminent we waited about 15 minutes and it would start and run fine. When turned off it may not start.
Yesterday, I tried ether into the air cleaner (to eliminate a bad fuel pump problem) and it still would not start.
No engine warning light went on during the interminent phase.
What do you think is wrong or what else can I do to find the problem?
Nov 26, 2009 at 4:16 AM
JDL
  • 16,098 POSTS
Thanks for the donation. Did you visually check for spark at the plugs, engine cranking? If you have spark everywhere, use a gage and check fuel pressure. When you first turn the key on, no crank, can you hear the pump run for a few seconds?
Nov 26, 2009 at 5:47 AM
