2002 Ford Windstar Van won't turn over or crank
JAHAZIEL
Engine Performance problem
2002 Ford Windstar 6 cyl Front Wheel Drive
After driving five to ten miles then parking, the van will not start. When the key is turned there is no clicking or sound. The lights, radio, and electric windows work in both the accessories and ignition on position. When the key is turned to the 'ignition start' position, the dashboard lights come on as normal. I have changed the starter thinking that it may be overheating. The van does start after a half an hour to three hours. Could this be an electrical ignition malfunction?
May 7, 2010 at 7:44 AM
  • 110,248 POSTS
Have you checked to see if there is power to the starter relay?
May 12, 2010 at 3:37 AM
JAHAZIEL
No, I've not tested for current to the starter. After waiting for awhile the car starts. I did change the starter. How would I test for intermittent power to the starter?
May 12, 2010 at 6:37 AM
  • 110,248 POSTS
Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter.
May 13, 2010 at 1:16 AM
