2002 Ford Windstar vAN HEIGHT
2002 FORD WINDSTAR
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
AMSCLINIC
Is there any way to get the van to be 1 to 2 inches higher off the floor? It is very low and scratches the asphalte when I enter my steep driveway. Can changing the shocks do it?
Nov 13, 2008 at 10:46 PM
BLACKOP555
  • 10,386 POSTS
if its just hitting the body you can put on a body lift.
or if its hitting body and suspension you can put on a body lift and largler tires.
what kind of suspension you have in the front, coil springs? struts? same for the back.
Nov 14, 2008 at 5:35 AM
AMSCLINIC
[quote:a233dd8166="blackop555"]if its just hitting the body you can put on a body lift.
what kind of suspension you have in the front, coil springs? struts? same for the back.[/quote:a233dd8166]
THE SUSPENSION IN THE FRONT IS STRUTS AND IN THE BACK COILS.The Ford garage told me that I shouldn't put higher tires because it will mess up my transmission, what is your opinion on that?
Nov 14, 2008 at 7:16 AM
BLACKOP555
  • 10,386 POSTS
dependent on the size of the wheel you put on you may have the speedometer show a slower speed then what you are actually going at. but it wont mess up the trans as long as they are all the same size.
Nov 14, 2008 at 9:47 AM
