No speedometer
1RCASE1
My speedometer quit working about a week ago. The odometer isn't working either. I have warning lights on the dash for the brakes and airbag. Once in drive, the Overdrive light flashes continually. The air compressor does not engage even though the led on the controls comes on.
Jun 2, 2009 at 1:23 PM
  • 55,710 POSTS
It sounds like you have a vehicle speed sensor that has gone out and needs replacement. You will need to jack the car up to replace it.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a VSS location diagram (below) for the sensor you may find it on Amazon or Rockauto
Cheers, Ken
Jun 5, 2017 at 10:02 AM
ELISELC2000
Electrical problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic 130000 miles
Heater and speedometer stopped working and I don't know why.
Jun 5, 2017 at 10:04 AM (Merged)
LARISSA_KLOCK
I had the same problem on my 2000 Windstar not too long ago. I was informed by local mechanic that it was actually a warranty issue.
I thought my brake cylinder was bad, but it turned out to be the brake pressure switch and it kept blowing fuses. I replaced it and haven't had any trouble since.
Hope this helps!!!
SCOTT77
I had the same issue in my 2000 windstar but for me the problem was break fluid dripping onto my cruise control harness and shorting out the items running on that fuse...speedometer, cruise control, heater etc...After disconnecting the CC harness no more problems but also no more CC. :-0)
2CP-ARCHIVES
  • 4,540 POSTS
1999 Ford Windstar mileage: 92,000. Recently we had another new transmission replaced (the second one in less than a year and the warranty had just went out on the first one) in our van. They also replaced the speedometer cable, after reaching 40 mph it was swinging back and forth between 40-65 mph making it difficult to get an accurate speed (that didn't work). My question is do we need to have the speedometer head replaced/rebuilt and will that damage the transmission if we don't get it done right away?
2CP-ARCHIVES
  • 4,540 POSTS
The speedometer problem may be caused by the speedometer cable binding or the speedometer head itself. If it is the cable, other than the uneven speed reading, it should cause no problems. If it is the head, it may break the new cable.
SCOTRIANI
  • 11 POSTS
OK - I know - you buy a used car, you buy someone else's problems. That being said. I bought a 98 windstar with a non-functioning speedo. Thought to myself that it can either be (1) bass VSS, (2) bad speedo, or (3) bad speedo cable. So, I checked the VSS visually and looks good, checked with tester, reads good. Plugged in the actron and ran the current data and vehicle speed is being passed properly to the OBD. Must be the speedo. So, I take off the speedo and replace, still no go. Notice that not only is there not a speedometer cable in this van, there doesn't even seem to be any reasonable place for one to be. I know in 98 some Windstars had digital clusters and some had analog. Currently, this thing has analog, but the previous owner did some funky stuff in the past and replacing a digital with an analog seems right up their alley.
My question is either this: Should I just buy a speedo cable and run it to the cluster?
OR
Is there any way Ford can tell me off of the VIN if this thing did have a digital cluster to begin with
OR
Are the plugs the same in the back for the digital vs. analog? If so, can I just get a digital one, plug it in, and ignore the speedometer cable altogether?
98 Windstar, 94683 miles. Speedo/Odometer not working, speed is being sent properly to the computer, though.
BRUCE HUNT
  • 3,754 POSTS
I would venture that off of the tranny there is either a connection for a cable or not. It is possible that they have both on the tranny during a period of conversion. If the speedometer has a connection for the cable, that is what I would go with after making sure the tranny connection is turning properly.
SCOTRIANI
  • 11 POSTS
Justanold - you may have solved this (if not, you sure know a hell of alot more than every stroke I have talked to at the three dealerships around me and gave me something to look at it). I will run up right now and check this out and let you know what I find
SCOTRIANI
  • 11 POSTS
OK - first thing, no fuse at 35 - owner's manual shows it as not used. There is a fuse (15A) at 25 that is OK. So then I checked the cluster connections and I have voltage on all of the right places and a good ground on it. Here is a pic of the back of the cluster that I removed...
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02308_1.jpg
And a closeup of where I think the speedo cable should be:
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02310_1.jpg
My concern is that I don't see any evidence that a cable used to be in there... but I looked at the back of a digital cluster from a 97 and the connections seem different than the two clips I have there. Any thoughts?
SCOTRIANI
  • 11 POSTS
Build date 6/98... engine 3.8L v6
So, I started checking connections and I have a subscription to Alldata for this van. So far, troubleshooted stepsF1-F5... got to F6 which told me to check resistance on C397 for less than 5 ohms in run. I'm at 6 ohms. Now here is where the trouble comes in. It says to service 397 and retest. I have experience in electronics (primarily guitar and amp repair, stereo stuff, etc.). If it tells me to service 397, do they want to have me replace the cable? Or can I put a resistor inline to bring it below 5 ohms?
SCOTRIANI
  • 11 POSTS
F78F-10C956 - B
That looks like the part number (right on the PCB)
As far as an accident... I bought the van used. No serious accidents from what I could tell. It does look like at one point there was a minor front end impact which required a replace and respray of the front bumper.
SCOTRIANI
  • 11 POSTS
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02313_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02314_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02315_1.jpg
SCOTRIANI
  • 11 POSTS
It's hard getting a clear picture... all of these were taken with the camera sitting on the floor so I can't get a good wide angle. I hope these help. If not, let me know more specifically what you're looking for and I can see what I can do. Thanks!
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02316_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02317_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02320_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02321_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02322_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02323_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02324_1.jpg
https://images.2carpros.com/forum/automotive_pictures/79456_DSC02325_1.jpg
SCOTRIANI
  • 11 POSTS
Wow... OK - so that worked. I have no idea why because my chilton's book, my alldata, and my haynes as well as the owner's manual mention 35 as not used. So, now can I ask what that fuse controls so I can make a note in my stuff?
On a side note, you have no idea how relieved I am. I have been messing with this for three days. Four different Ford dealers have told me that I needed a speedo cable, needed to replace the VSS (even though I was getting speed info from the computer), and needed to replace the cluster with a new one. I did replace the cluster (boneyard part) because the last one looked pretty bad (black tar type substance in it) but I have been at wits end and testing each connection, etc.
:D
SCOTRIANI
  • 11 POSTS
Hey there... I want to give you good feedback but I only have .3 of a point... how do I get more points to give you some positive feedback?
COREYC1969
Electrical problem
2000 Ford Windstar 4 cyl Front Wheel Drive Automatic
the speedometer does not work
DAVE H
  • 13,383 POSTS
replace the VSS (vehicle speed sensor)
NMMKK99
Computer problem
1999 Ford Windstar 6 cyl All Wheel Drive Automatic 89000 miles
Speedometer quit working and the odometer just shows all dashes. What might have happened?
BAD74CHARGER
  • 8 POSTS
Its sounds like the VSS went bad. vehicle speed sensor
PUMPDOCTOR
Air Conditioning problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic 186000 miles
While driving my van with air coditioning on and running fine.. all of a sudden the ac was not cool anymore and the speedometer and odometer stopped working. The ac fan still runs but no cool air and the Overdrive light is blinking and appears to no go into overdrive. yes, check engine lite came on.
the code says vehicle speed sensor circuit faulty and or no input ...... can you help? I just got laid off from my job and cannot afford to go to dealer or shop.
I fix pumps and steam turbines as my job and have plenty of time and tools. Where do I go from here? What do I check?
Autozone says the VSS should be changed but that won't fix the ac .... I'm thinking a fuse or relay?
Please help.....
I just found fuse #10 driver side under dash is blown 15A Why?
