2002 Ford Windstar Leak
78,794 MILES • 4 CYL • FWD • MANUAL
LULU1219
I have a leak that has a funny odor when the heat is on and I am parked. There is a leak under the engine on the passenger side. The inside hood of the minivan is wet on the passenger side. It appears it be leaking antifreeze.
Dec 3, 2007 at 11:38 AM
  • 31,937 POSTS
Hi there,
You may have developed a leak in the heater core, have the cooling system pressure tested with the heater tap on hot. Tell your mechanic that you suspect the heater core is leaking, so that he /she can inspect it closely.
Mark (mhpautos)
Dec 3, 2007 at 12:34 PM
  • 31,937 POSTS
sorry my error, it's a case of different terminology, justanold is quite correct and i do apologise if i miss lead you. In Aust the "Hood" can mean the roof lining" and i was wandering down the wrong road.
Mark (mhpautos)
Dec 3, 2007 at 8:49 PM
