2002 Ford Windstar Information Panel in Dash
43,000 MILES • 6 CYL • FWD • AUTOMATIC
352DENNIS
The information panel in the right lower corner of the dash stopped working. I checked all the fuses in the fuse panel under the dash and they all look fine. I plugged in my OBD reader and it shows no code faults. What do you suggest I look for to fix the problem? Thanks for your help. Dennis.
Nov 23, 2008 at 8:15 AM
RACEFAN966
  • 5,029 POSTS
Ok from what I can find it looks like you either have a bad instrument clucter or and IC module problem. Either way it is a very intense test that requires equipment that most do it yourselfers don't have. I would recomend taking it to a know good repair shop.
Nov 24, 2008 at 3:14 AM
