2002 Ford Windstar heater/ac controls
70,000 MILES • 6 CYL • FWD • AUTOMATIC
CHUCK_MCBREEN
There is a noise coming from under the dash, click click click and the ac and the heater is running at the same time I think the controls are eletrical and vaccum operated and I think the heater valve is stuck, how do I go about fixing this15.00
Apr 24, 2009 at 6:36 AM
MERLIN2021
  • 17,250 POSTS
Sounds like the temperature blend door actuator, or the door itself is stuck, and the actuator cant move it. Try removing the actuator, spray some WD-40 on the shaft and move it back and forth until it moves freely, then re install the actuator.
Apr 24, 2009 at 8:02 AM
