2002 Ford Windstar deloris
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
DELORISWILL36
Hi my name is Deloris and I am haveing problem with my heat.My winderstar van blows out cold air in front and hot in the back. Do I need to replace the front or could it be a relay.
Dec 3, 2008 at 11:10 AM
DAVE H
  • 13,383 POSTS
the relay is fine if the motor is blowing air ...have your mechanic check the heater core is not blocked .. theres no air in the system .. no leaks .. pressure test system ...
Dec 20, 2016 at 1:11 PM
