2002 Ford Windstar Cruise control and no freon in system
2002 FORD WINDSTAR
15,000 MILES • 6 CYL • FWD • AUTOMATIC
GARY JOHNSON 1948
I am buying this car and the cruise control doesn't work at all, a local mech with 40 plus years says no big problem, and the a/c has no freon in it, I worked on home a/c and a few cars. Is there a common problem with either? I know there has to be a leak, but no sight of any leaks is seen. I have also looked at the recall on the brake fluid leaks, and ther is none, completely dry. Any suggestions? The car is spotless outside, and only dirty carpets and everything else seems to wrk fine. It a 2002 LX Thanks Gary
May 19, 2010 at 10:24 PM
  • 110,194 POSTS
Chances are the cruise control has something to do with either the switch itself, a loose wire, or speed sensor. Chances are it isn't a big deal.
As far as the freon, it could be leaking anywhere. There is no one common problem with them. The only thing you can do is recharge the system and see if you can find a leak. Keep in mind, AC parts can get expensive.
PS: As far as the recall, it may have already been taken care of.
May 19, 2010 at 10:53 PM
