2002 Ford Windstar
14,600 MILES • 6 CYL • FWD • AUTOMATIC
DMCLOUSE34
STARTED IT RAN TURNED IT OFF. WENT TO START IT AND IT STARTED AND DIED. WON'T START AND ALL. THE FUEL PUMP IS RUNNING AND IT HAS SPARK.
Sep 3, 2010 at 2:08 PM
  • 75,988 POSTS
Check the fuel pressure if it's within specs to rule out the fuel filter and fuel pump,also are the injectors pulsing?
Sep 3, 2010 at 9:57 PM
DMCLOUSE34
WHERE IS THE BEST PLACE TO CHECK THE FUEL PRESSURE? I TOOK THE FUEL FILTER OFF AND WHEN YOU KICK ON THE FUEL PUMP FUEL COMES OUT AT A STREAM.
DO YOU THINK THAT IT COULD BE OUT OF TIME? IT NEVER RAN ROUGH OR ANYTHING. THAT IS WHY I FIGURED IT WAS SOMETHING WITH THE FUEL SYSTEM.
HOW DO YOU CHECK THE FUEL INJ?
Sep 4, 2010 at 1:57 AM
  • 75,988 POSTS
Listen to the injectors if its clicking or just a use a noid lite-to read fuel pressure hook up on the fuel rail test port
Sep 4, 2010 at 4:15 AM
