2002 Ford Windstar
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MSAMAQBOOL
ABS brake light (yellow) and brake light (red) simultaneously becomes on during hot season. I am facing this problem for the last 2 years.
I have checked speed control deactivation switch wiring (2 wires) located on bottom side of the Master Cylinder. No leak brake fluid is observed on these wires.
Cruise control is also not working for the last one month.
Jul 5, 2010 at 8:28 PM
DAVE H
  • 13,383 POSTS
have the vehicle plugged into a diagnostic computer to check for ABS fault codes ... NOTE .. most generic scanners will not retrieve ABS codes .. you will have to have a shop pull the codes for you
Jul 5, 2010 at 8:56 PM
