2002 Ford Windstar
90,000 MILES • 6 CYL • FWD • AUTOMATIC
DIONEV5
I have a cylinder 6 missfire.
Codes P0306 and P0174.
I replaced the ignition coil, wires, spark plugs, filters compression is 170
and still have the same problem...
Where is the problem....
Jun 16, 2010 at 9:23 AM
  • 110,248 POSTS
If you remove the spark plug, does it appear to be working or is it wet with gas? HAve you checked the injector for that cylender. Is the plug getting spark?
Jun 24, 2010 at 3:59 PM
