2001 Ford Windstar Passenger Door Ajar?? But its closed?!
139,910 MILES • 6 CYL • 2WD • AUTOMATIC
CUBANMAN123
I have a 2001 Windstar SEL. When it is cold the car doesnt act up. But when it gets up 70 degrees (almost everyday in miami). The Message Board says PASSENGER DOOR AJAR. (the front not the sliding door). We have replaced the door ajar switch, but with no results! Do you think it could be the latch?
Jan 24, 2009 at 4:38 AM
BMRFIXIT
  • 19,053 POSTS
Check if any of the door sagging and also check the door hinges
use WD40 on the door latches
Jan 24, 2009 at 6:32 AM
