2001 Ford Windstar Overdrive light flashing
10,700 MILES • 6 CYL • 2WD • AUTOMATIC
SANDSSMITH
Transmission jumped out of overdrive. The overdrive off light is flashing and the check transmission light is on. It shakes when you first take off and straightens out a little after going about 20 miles an hour. I have changed the transmission fluid and filter. And it still will not go into overdrive and shifts hard into park, reserve, and drive. Do you think this could be a sensor, or something internal with the transmission?
Sep 28, 2008 at 7:33 AM
2CARPRO JACK
  • 11,533 POSTS
The lights are an indicator that the PCM sees a problem with the trans/controls.Have the PCM scanned for codes first to see what th P CM has stored as far as codes goes, this may lead to the fix for your vehicle
Sep 29, 2008 at 4:46 AM
