2001 Ford Windstar Gas Smell????
MANDYKG
Smells problem
2001 Ford Windstar 6 cyl Automatic
I have noticed a gas smell more on the drivers side in middle seat of my van. I think it only happens when i have the air turned on. It happened last summer and then i didnt notice it all winter and its doing it again now that im using the air conditioner again. We took it to get it checked out and they couldnt find anything.....What could be the problem?
May 12, 2010 at 3:33 AM
  • 110,251 POSTS
Do you only smell it inside with the air on? Do you have rear AC? Have you checked fuel lines for leaks?
May 12, 2010 at 3:36 AM
MANDYKG
Yes I've only noticed the smell when the air is on and only inside I'm pretty sure. I do have vents in back also. The people we took it to said they checked everything and didn't find a leak though. If it keeps doing it I guess I need to just take it somewhere else
May 12, 2010 at 3:52 AM
  • 110,251 POSTS
If you smell it in the vehicle with the AC running, the leak is under the hood. Did they check the injectors?
May 12, 2010 at 6:48 AM
ARCHITECTURALGUY
Thats my issue. Only when AC is on. I have looked everywhere without success. If it is the injectors, would a injector cleaner work?
Aug 23, 2014 at 1:49 AM
