2001 Ford Windstar fuel
DGH
Engine Performance problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic
when i am driving the van will start to slow down like it is not getting fuel
Feb 5, 2010 at 7:53 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 5, 2010 at 11:36 PM
