2001 Ford Windstar Dash lights with both brake and ABS
2001 FORD WINDSTAR
VIRGIL BROWN
Electrical problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic
For 3 or more years on occasion both the red brake light and the orange ABS lights will light at the same time. When the key is turned to the off position, it resets the lights to stay off for a while before reappearing. It causes no problem with brakes or operation and it might go for weeks without coming on. At other times it may come on every time you drive it for a week or two and then just fade away for a while before reappearing again later. It seems like a loose connection or a loose ground that heels itself. I added extra ground cables, but did not help. Have you ever heard of anything like this and is it something you can tell me how to fix?
May 28, 2010 at 8:33 PM
JIS001
  • 3,412 POSTS
You need to have the ABS module scanned for codes and fault trace from there? Can be a bad ring on the axle, bad abs wheel sensor, loose hub, all the way to the control module being faulty? If you can post some codes on here, maybe I can point you in the right direction.
May 28, 2010 at 11:45 PM
