2001 Ford Windstar check engine light
106,000 MILES • 6 CYL • FWD • AUTOMATIC
JENNEFER229
my van has been sputtering and acting as if it didnt want to go up hills. I changed the air filter and then it seemed fine for 2 days. Then it started again and stalled out a couple times. the check engine light came on for a while and I got a code for it but couldn't find what the code meant. It was p1576. Do you know what this code is?
Apr 10, 2008 at 11:49 AM
SCOTT77
My OBD-II scanner software shows the code p1576 to be
"Pedal Position Not Available" ....
Apr 26, 2008 at 9:22 AM
