2001 Ford Windstar Abs and trac lights are on
97,000 MILES • 6 CYL • FWD • AUTOMATIC
BUSHANIC
I have read a lot on this subject and I have got the codes 15 of them. the one I think might the cause of all the other is C1185 ABS power relayoutput failure coulds this cause other codes to be loged.
-also if I replaced the ABS module with one out of a working van would it still need to be program by the dealer.
the dealer i spoke with said they would need to replace the HCU and the ECU for a total of 2100. They could not give me a good reason for having to do both but just said they've had it to come back and BITE them in the BUTT.
Here are the codes C1236,C1235,C1134,C1185,C1198,C1194,C1254,
C1246,C1250,C1242,C1214,C1210,C1410,C1404,
U1262. THANKS FOR YOUR HELP.
Apr 23, 2009 at 1:41 AM
MERLIN2021
  • 17,250 POSTS
Although you have all these codes, and it usually means part replace ment, go here and try this repair, and unplug and clean any brake fluid out of the connections.
Apr 23, 2009 at 8:16 AM
