I have problem with power window, power lock and some other electrical issues... Due to the voltage???
May 10, 2008 at 3:36 AM
MERLIN2021
✓Experienced Mechanic
These controls go thru the driver's door mudule, then the GEM module, check the voltage with a voltmeter at the battery terminals, with the engine running it should be 13.8-15 volts. These modules are fairly expensive, so I would have the van scanned for codes, by a shop that can read body codes...
