2000 Ford Windstar Voltage
JSJORTIZ
  • 2000 FORD WINDSTAR
  • 6 CYL
  • 95,000 MILES
I have problem with power window, power lock and some other electrical issues. Due to the voltage?
Saturday, May 10th, 2008 AT 10:36 AM
MERLIN2021
  • 17,250 POSTS
These controls go thru the driver's door mudule, then the GEM module, check the voltage with a voltmeter at the battery terminals, with the engine running it should be 13.8-15 volts. These modules are fairly expensive, so I would have the van scanned for codes, by a shop that can read body codes.
Saturday, May 10th, 2008 AT 10:58 AM
