2000 Ford Windstar VAN WILL NOT IDLE
BILL71886
Engine Performance problem
2000 Ford Windstar 6 cyl Automatic
I replaced fuel pump and filter old pump only had 18 lbs of pressure van wont idle i have to give it gas to keep it running why?
Dec 4, 2009 at 2:06 AM
BLACKOP555
  • 10,386 POSTS
what pressure is the new pump and filter putting out?
was filter put on the right way, if its backwards it restricts it. could be a bad fuel pressure regulator. or a bad idle motor. did it idle good before replacement? try running some highly concentrated seafoam through the system
Dec 4, 2009 at 7:41 AM
