2000 Ford Windstar speedometer/odometer
ADLIN
  • 6 POSTS
Electrical problem
2000 Ford Windstar 6 cyl Automatic
2000 FORD WINDSTAR IN THE ODOMETER YOU CAN SEE THIS ------------- INSTEAD OF MILLAGE NUMBERS, WHAT CAN BE THE PROBLEM.... AND ALL THE LIGHTS IN THE SPEEDOMETER ARE ON, I MEAN, ABS, CHECK ENGINE, OVER DRIVE...ETC
May 12, 2010 at 6:37 AM
  • 110,248 POSTS
Did this happen all at once?
May 18, 2010 at 6:26 AM
ADLIN
  • 6 POSTS
[quote:b909cb8f64="Jacobandnickolas"]Did this happen all at once?[/quote:b909cb8f64]
NOW IS THE SPEEDOMETER AND ODOMETER THAT DOESNT WORK, CAUSE I PUT A NEW TRANSMISSION SENSOR AND THAT FIX THE OTHER LIGHTS PROBLEMS EXCEPT THE SPEEDOMETER
May 18, 2010 at 8:26 AM
  • 110,248 POSTS
Do you have a digital odometer and a standard speedo or is the speedo digital too?
May 18, 2010 at 1:54 PM
ADLIN
  • 6 POSTS
[quote:938f1200ef="Jacobandnickolas"]Do you have a digital odometer and a standard speedo or is the speedo digital too?[/quote:938f1200ef]
i have a digital odometer and a standard speedometer
May 18, 2010 at 11:28 PM
  • 110,248 POSTS
Either you got
May 19, 2010 at 12:48 AM
ADLIN
  • 6 POSTS
[quote:47639de599="Jacobandnickolas"]Either you got[/quote:47639de599]
is like this one http://www.youtube.com/watch?v=ouno9F3twLA
May 19, 2010 at 1:25 AM
ADLIN
  • 6 POSTS
[quote:8c29a859bd="Jacobandnickolas"]Either you got[/quote:8c29a859bd]
May 19, 2010 at 1:26 AM
  • 110,248 POSTS
Wow! It looks like you may need a priest and not a mechanic. Actually, I think the body control module (BCM) may be the cause. I would recommend having that checked.
May 19, 2010 at 3:48 AM
SCOTT CASTOR
  • 5 POSTS
contact ford with your VIN number there is a recall to fix that
Jun 24, 2010 at 2:18 PM
