2000 Ford Windstar Speedometer & Tachometer
154,000 MILES • 6 CYL • FWD • AUTOMATIC
GWENDOLYN51
all of my gauges including Speedometer & Tachometer are jumping and the tachometer seems to be stuck now at the far end of the gauge. What can be wrong?
Aug 25, 2008 at 5:37 AM
2BROKE
I just had that same problem and had to replace the instrament cluster which is everything that you see and can't behind the tach and speed gauges
Sep 4, 2008 at 10:17 AM
2BROKE
Oh left out the most important thing cost parts around 4 to 5 hundred labor 100
Sep 4, 2008 at 10:19 AM
SKCORPIO5764
Hi ! Are you Gwen Spells from Indy ? If so we met on BPM ! Get in touch with me if you like 765-313-1814 or douglasallen04@comcast.net Yours Douglas
Oct 13, 2013 at 1:45 AM
