2000 Ford Windstar shifter
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHARON SIMPSON
I pulled into work backed into my parking spot when I went to put it in drive it still went in reverse. I tried all gears and it still went in reverse I had to shut it off just to keep from hitting anything and to get it to stop, now because it is reverse it wont start eaither. I am a 53 yr old female single and know alittle about engines is there something I can do to get a quick fix until I can get it to shop
Aug 28, 2008 at 12:44 AM
DOCFIXIT
  • 18,828 POSTS
Maybe the shift linkage came off. Open hood look at trans see if cable or connection to shift lrver is off. You maybe able to rig a repair to get to shop[.
Good luck
Aug 28, 2008 at 12:52 AM
