2000 Ford Windstar Part Identification and Installation
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DHUMMEL50
I was putting the upper pipe onto the water pump. While doing this I bumped a small S-shaped "wire" looking piece on the pulley side of the engine up toward the intake with small washers on the end loose. I was wondering what the piece is and how to reattach it.[img:c984191757]http://www.2carpros.com/forum/automotive_pictures/365328_DSCN3534_1.jpg[/img:c984191757]
Jun 5, 2009 at 6:41 AM
2CARPRO JACK
  • 11,533 POSTS
That looks like the rod for the intake runners(IMRC).There should be an electric motor and an arm on the intake manifold that it attaches to.You will need to go to Ford to get new retainer clips, those breaking is a common failure on those engines. Its a bad pic, but it is the only one I canfind
https://images.2carpros.com/forum/automotive_pictures/1639_imrc_1.jpg
Aug 15, 2020 at 3:32 AM
