2000 Ford Windstar Operating noise
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
REH22
I have a noise what I called moaning/groaning sound when driving. In cooler weather it is ok. After driving for a while or in hot weather it happens . I haved replaced the power stiring unit twice in less than a year a part and before replacing them I had the same sound. I hear the noise when the car is setting still as well a moving. When turning it seems louder. What is causing this??
Jul 29, 2008 at 1:34 AM
THIS IS MIKE
  • 686 POSTS
It sounds like your power steering pump is making the noise. Check to see if you are you loosing any fluid and top off if necessary. Also check your power steering hoses to make sure there are no loose connections or too close to a heat source. When replacing the unit make sure you are using an OEM part (Original Equipment Manufacturer) The aftermarket units are not as good and may fail prematurely.
Jul 29, 2008 at 10:32 AM
2CARPRO JACK
  • 11,533 POSTS
Most Ford replacement pumps require a break in period for whatever reason, usually there is a tag notifying the installer of a 500 mile time frame. Also might want to try adding a small amount of motor oil (2-4 tbsps) this sometimes will help the noise problem. Other than that, check all things Mike suggested as well
Jul 30, 2008 at 2:23 AM
