2000 Ford Windstar O2 sensor
DADDY CANE
  • 5 POSTS
Engine Performance problem
2000 Ford Windstar 6 cyl
anyone know where bank 1 is located.. im not paying for 4 of them.. too much $ that i dont have.
thank you in advance.... :-p
Jul 28, 2009 at 8:50 AM
  • 75,988 POSTS
Ref: Posted at Mon Feb 16, 2009 12:32 am
By tjiowa, Likes to hang around!
Give Feedback | Votes: 0
2000 Ford Windstar 6 cyl Two Wheel Drive Automatic 67000 miles
The check engine light came on. I hooked up my OBD 2 up to it. It said it was lean on both bank 1 & bank 2. I'm assuming by bank it means both fuel injector rails? Van runs fine when I clear the code, but within 150 miles,(sometimes less) the check engine light comes back on again.. saying the same thing. Banks 1 & 2 are lean. Any suggestions as to what I can do to fix this problem? I have noticed that it's not getting the gas mileage it should be getting.
Also, the radio stays on when I shut the van off. I make sure all the electrical stuff is in the off position when I shut the van off, or over a couple of days the battery gets drained.
Posted at Tue Jul 28, 2009 2:45 pm
By Daddy Cane, Likes to hang around!
running lean "bank 1" is your O2 sensor
Which engine 3.0 or 3.8?? both has it on the right exhaust manifold
Jul 28, 2009 at 9:00 AM
