2000 Ford Windstar lean codes in bank 1 and 2
145,000 MILES • 6 CYL • FWD • AUTOMATIC
HCASTEEL
What is the most common cause for this van to have banks 1 and 2 lean? I have replaced o2 sensors, vacuum lines, and cleaned out intake with sea foam. I have had in shop 5 times and I get the same thing every time I get it back. After 2 days I get the codes right back after spending up to $100.00 at a time. Can you please help me with this issue?
Jun 4, 2010 at 11:39 AM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
Jun 4, 2010 at 12:00 PM
