2000 Ford Windstar Leaking Coolant
122,945 MILES • V8 • FWD • AUTOMATIC
MLOW514
  • 5 POSTS
my car sprays coolant from the engine almost like a srpinkler causing my temp to go up What's the problem and how do i get it fixed?
Oct 4, 2010 at 5:33 AM
WRENCHTECH
  • 20,758 POSTS
You first have the cooling system pressure tested to determine what is leaking and have it repaired. Hopefully you haven't already done serious damage to the engine by driving it hot.
Oct 4, 2010 at 6:30 AM
MLOW514
  • 5 POSTS
even if i can visibly see the coolant spraying out?
Oct 4, 2010 at 7:03 AM
WRENCHTECH
  • 20,758 POSTS
If you can see where it's coming from, then that's what needs to be repaired. I surely can't see it from here to tell you what it is.
Oct 4, 2010 at 9:41 AM
MLOW514
  • 5 POSTS
well it's leaking from the intake manifold
Oct 14, 2010 at 11:30 AM
