my car sprays coolant from the engine almost like a srpinkler causing my temp to go up What's the problem and how do i get it fixed?
Oct 4, 2010 at 5:33 AM
WRENCHTECH
✓Experienced Mechanic
You first have the cooling system pressure tested to determine what is leaking and have it repaired. Hopefully you haven't already done serious damage to the engine by driving it hot.
Oct 4, 2010 at 6:30 AM
MLOW514
MEMBER
even if i can visibly see the coolant spraying out?
Oct 4, 2010 at 7:03 AM
WRENCHTECH
If you can see where it's coming from, then that's what needs to be repaired. I surely can't see it from here to tell you what it is.
