2000 Ford Windstar leaking antifreeze
PEPEG
  • 2000 FORD WINDSTAR
  • 6 CYL
  • 105,000 MILES
Hello my van is leaking antifreeze I check all the houses and they look OK at first it look like it was leaking from thermostat housing and I replaced and seal but when I put the antifreeze star the liking and it wasn't from the thermostat but the leaking is close to it what could it be
tank you
Tuesday, November 18th, 2008 AT 6:59 PM
  • 31,937 POSTS
Hi there,
if you get the engine cleaned down and get a mechanic to do a pressure test on the cooling system, he will be able to see where the leaks is coming from and advise you on the correct action, this is one of those things that really need to be seen first hand to advise correctly.
Mark (mhpautos)
Tuesday, November 18th, 2008 AT 7:20 PM
