2000 Ford Windstar Knocking or bumping sound when heat is r
186,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMWINDSTAR
The A/C works with a knocking sound under the middle of the dash board.
When heat is requested, no heat but the knocking sound continues.
Sep 18, 2009 at 4:50 PM
KBNET56
[quote:636f81c416="JimWindstar"]Heater problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic 186000 miles
When heat is requested, no heat but the knocking sound continues.[/quote:636f81c416]
i just had the problem fixed in my 2000 ford windstar..it is the actuator motor.. stripped gear.. however also common to the problem is the blend door.. being plastic.. frequently cracks and then flops.. i changed both.. i got an upgrade blend door all metal from heatertreater.net
mine was doing the same thing blowing cold and knocking noise..
Sep 20, 2009 at 11:09 AM
SHERRIKARPINSKI
Can you tell me approx. the cost to repair this and if you did it yourself? Email me at sherrikarpinki@hotmail.com. Mine is a 2002 with 88000 miles and the back heat works, but the front only blows cold air.
Thank you
Sep 28, 2009 at 2:43 AM
