[quote:636f81c416="JimWindstar"]Heater problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic 186000 miles
The A/C works with a knocking sound under the middle of the dash board.
When heat is requested, no heat but the knocking sound continues.[/quote:636f81c416]
i just had the problem fixed in my 2000 ford windstar..it is the actuator motor.. stripped gear.. however also common to the problem is the blend door.. being plastic.. frequently cracks and then flops.. i changed both.. i got an upgrade blend door all metal from heatertreater.net
mine was doing the same thing blowing cold and knocking noise..
Sep 20, 2009 at 11:09 AM
