2000 Ford Windstar knocking
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLIFF123
I heard knocking start at the upper part of the engine sonds like underneath the manifold. Also can you feel with your hands whether a rod is attached or not on top of the engine?
Nov 21, 2008 at 5:57 AM
  • 75,988 POSTS
This sound is it a ticking, tapping, thuddding and thumping and increases with rpms ?
Nov 21, 2008 at 6:07 AM
CLIFF123
its a rapping sound. sounds like a belt but maybe a rod or rocker. this happen with these vehicles?
Nov 21, 2008 at 7:37 AM
  • 75,988 POSTS
With the engine running and the rapping noise present, get a long
screwdriver and place the handle against your ear or other part of
your head so that sound will conduct through the screwdriver, then
start placing the screwdriver against various accessories until you
hear the one making the most noise. It will be evident right away
what the source is.
Could also be a piston slap-Try running the engine while disconnecting plug wires one at a time to located where the most noise is coming from
Nov 21, 2008 at 9:06 AM
