2000 Ford Windstar help
LILMISS6
Electrical problem
2000 Ford Windstar Two Wheel Drive Automatic
i have a 2000 ford windstar and the gear shift keeps getting stuck in park, and the same fuse keeps blowing, the brake lights don't work at times, and when the engine is off the a/c blows air.
Jul 29, 2010 at 7:55 PM
EDWARD.S
  • 166 POSTS
Hi, Have The Brake Light Switch And Connector Checked, You May Need a Brake light Switch And or connector too. If They only Work sometimes ,Then That Is why It's Getting stuck in park. As for the Fuse, Which fuse Keeps Blowing?,And You Stated the Ac Blower is Working Without The Ignition On? That Could Be a short Circuit.Or Wires Fused Together. Also Could Be Something Wrong In the Ignition Switch.Have A Electrical Shop Look Into That Part Further.
Hope This Helps You,
Good Luck
Edward S.
Jul 29, 2010 at 10:25 PM
LILMISS6
its fuse #11 i think i know its blue and 15amp.
Jul 30, 2010 at 12:02 AM
