2000 Ford Windstar Heater Problems
86,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSSMC
Our heater has quit working in the front, but still partially works in the back. It is warm but not hot. The front only blows extremely cold air. The heater core is working. What are the possible causes. Thank you for your time.
Jan 18, 2008 at 4:47 PM
  • 75,988 POSTS
Check the coolant level-disconnect the heater hoses and inspect for clogging-also the heater core use the garden hose trick and reverse flush it. Might want to replace the thermostat-good investment.
Need more help don't hesitate to ask-you don't ask -you'll will never know.
Dec 20, 2016 at 10:22 AM
