what causes knocking in the engine and what needed to repair it
Dec 3, 2008 at 1:14 AM
RACEFAN966
✓Experienced Mechanic
Ok this can be caused buy a number of things. First is the oil level correct? How does the knock sound is it a light tapping type knock or a deep lower knock? If it is a lower knock then you will need to replace or rebuild the engine. Let me know what you can and we will go from there.
