2000 Ford Windstar DOESNT WANT TO IDLE
ALLENOVERHOLT
Engine Performance problem
2000 Ford Windstar 6 cyl Front Wheel Drive Automatic 100K miles
WONT IDLE. HAS A HISSING SOUND AT TOP BACK OF MOTOR. ALL HOSES HOOKED UP. JUST STARTED A WEEK AGO. RUNNING ROUGH
Feb 12, 2009 at 12:46 PM
  • 110,246 POSTS
Hi:
You have a vacuum leak somewhere if you hear a hissing. Checl for it around the rear of the intake.
Some mechanics use starting fluid to find leaks. If there is a leak, it will suck it in at the leak and the RPM's will raise. I don't do this because of the potential of catching something on fire, but many do it.
Let me know what you find.
Feb 14, 2009 at 6:22 AM
ALLENOVERHOLT
put new wires, plugs, air filter, pvc. checked fuel filter its ok. idles better but still not getting good response on acceleration. seems to hesitate and take alot of peddle with no acceleration. o2 sensor? m.a.f. sensor? t.p.s. sensor? how can i find out without diagnostic tester? thank you for your help
Feb 14, 2009 at 7:42 AM
  • 110,246 POSTS
Hi:
Check this out for the O2 sensor. But you will need some general tools (a multimeter).
https://www.2carpros.com/how_to/how_to_test_oxygen_sensor.htm
Usually the check engine light will come on when the items you mentioned failure.
Also, you're sure the fuel pump is making enough pressure and the catylatic converter isn't plugged, correct?
Feb 14, 2009 at 9:56 AM
