2000 Ford Windstar codes
COMERCIALAUTOSERVICE
  • 48 POSTS
Engine Performance problem
2000 Ford Windstar 6 cyl Two Wheel Drive Automatic 120.00 miles
WE HAVE HAVE THIS VEHICLE IN MY SHOP
THE CAR HAVE THE CHECK ENGINE LIGHT ON
THE CODE IS
1-P-0171
2-P-0174
WE LIKE KNOW WHAT HAPPENED WITH THIS CODE AND LOCATED FOR REPAIR , EXCATLY I NEED LOCATED FOR THIS PART,
WE CLEANER AIRFLOW AND THE CHECK ENGINE LIGHT COME AGAIN
THX
Mar 24, 2010 at 2:44 AM
RACEFAN966
  • 5,029 POSTS
Ok with both these codes at the same time and having cleaned the mass air flow unit I would ask that you have a live scan done to watch the rear O2 sensors. I think you may find that they need to be replaced. Also check the egr control solenoid and the silicone tube to the egr for any cracks as this will cause these codes to come up too. Hope this helps.
Mar 24, 2010 at 3:18 AM
  • 48 POSTS
HI YOU CAN SEND A PIC FOR LOCATED THIS SELENOI THX
Mar 24, 2010 at 5:44 AM
