2000 Ford Windstar Brake Lights
2000 FORD WINDSTAR
230,000 MILES • 6 CYL • FWD • AUTOMATIC
RSHAW45420
I have replaced the Brake switch, checked all brake light fuses, and all bulbs. I have NO BRAKE LIGHTS. All my other lights work: parking lights, turn signal, back up, but again NO BRAKE LIGHTS. please help whats the problem
Feb 20, 2010 at 1:18 PM
MATHIASO
  • 1,209 POSTS
Hello rshaw45420
Is your left and right rear turn lamps , license ,right and left reversing lamps working?
Feb 20, 2010 at 10:16 PM
RSHAW45420
Yes all lights are working
Feb 21, 2010 at 1:14 AM
MATHIASO
  • 1,209 POSTS
Hello rshaw45420
First of all, we have to make sure the brake pedal is touching the switch when depressed,if not pull the switch out and reinstall it so it can be automatically adjusted when pedal is applied(.25inch ( 6.35mm))
Next check for battery power to the brake light switch,if there is no battery power, check fuse and check power to the fuse or check for open to the brake light switch, connector between battery junction box and central junction box.
If battery power is present at the switch, depress the brake pedal and check for battery power on the other side of the switch,which feeds battery power to the brake light bulbs.I know the switch is new one and if the brake light still do not operate, check for an open wire either on the battery feed side from the switch or ground side of the wire harness to the brake light bulbs
Feb 21, 2010 at 8:54 AM
