2000 Ford Windstar All accessory items failed
CAPT_JAKE
Electrical problem
2000 Ford Windstar 6 cyl Automatic 79000 miles
Car runs, lights work, but nothing else...Windows, heater, wipers directionals, idiot lights, speedometer, odometer, tach..all went at once...
I fear the module went bad...
Oct 20, 2010 at 9:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Very good sign that the PCM has indeed gave up the ghost
Oct 20, 2010 at 1:51 PM
CAPT_JAKE
yea...but at several hundred to swap out..is there any other options, have had grounding issues b4 on this van...
Oct 20, 2010 at 2:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you may check out the accessory delay relay to see if it has not failed before venturing to the PCM
Oct 20, 2010 at 2:55 PM
CAPT_JAKE
I swapped out with a PCM from a junk yard for $100...now won't start...still have headlights, running lights and emergency flashers...nothing else...
Oct 22, 2010 at 6:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The replacement PCM has to be programmed with a scan tool before it will work on your vehicle..
Oct 22, 2010 at 8:15 AM
