2000 Ford Windstar AIR CONDITIONER WAS WORKING NOW ITS NOT
136,000 MILES • V8 • FWD • AUTOMATIC
FRANKIE79013
EVERYTHING HAD BEEN WORKING ON MY VAN UP UNTIL YEATERDAY. AND THE ALL OF A SUDDEN THE AC STARTS TO BLOW OUT HOT AIR AND MY SPEEDOMETER STOPS WORKING AND MY MILAGE ISNT SHOWNIG UP ANYMORE. I DONT HAVE AN OWNERS MANUAL BUT I WENT AND BOUGHT A BOOK FROM AUTOZONE AND CHECKED THE FUSES BUT I ONLY GOT ONE OUT OF THE THREE PROBLEMS FIXED WHICH WAS THE MILAGE. I DONT KNOW WHAT ELES TO DO.
May 19, 2008 at 10:48 AM
SMOORE
I had the same problem with my 2000 Windstar. It ended up being a brake fluid leak around a sensor on the master cylinder. The sensor is a known issue and has been redesigned. The brake fluid dripped onto some elctrical connections causing fuses to blow. The sensor turns off the cruise control when the brakes are pressed. On some vehicles it was known to cause fires and Ford had to provide a recall. At the time my Windstar was not covered in the recall but it may be now.
Jul 22, 2008 at 3:16 PM
